Part Number: TPS65987EVM
We are designing a product in which we will need a docking station block.
For our application, we will need Type C cable which goes into host PC and it should charge the host PC, and simultaneously we should be able to use data (For connecting a USB device).
For checking this scenario, we are using TPS65987EVM.
When we programmed the EVM for DFP mode only then it only charge the laptop. We cant use the USB port (As a downstream port).
And when we programmed the EVM for DRP mode (prefers data) then we can only use the USB port(data) and no power for charging.
Can you please help us how to enable the Data and power modes simultaneously?
Please let me know if you did not understand our requirements properly, I can explain it in detail.
