Other Parts Discussed in Thread: TLV62569
Hi Team,
My customer has some application questions and my comments as below. Could you please help double check about them? Thanks.
1. Does TLV62569A with output discharge? -> No
2. What is the behavior of over current protection? Hiccup mode or Latch mode? -> Hiccup mode
3. Does TLV62569A have output OVP and UVP? -> No, we only track Vout to control PWM. The PWM will up to 100% when Vout OV and down to 0% when Vout UV.
4. Does PG will drop when output OV/UV? -> According to datasheet, the PG will pull low when Vout UV, but PG will not pull low when Vout OV.
Hardy
