I'm testing BQ27Z746 EVM and using a logic analyzer to capture the I2C data. I found when opening the BQS, I can find a command(0x3E,0x02,0xEE) which is not listed in datasheet or TRM. Would you please suggest what is this command for? you can for sure observe this when you open the BQS, thanks. (My FW: bq27z746_v0_01_build_12.srec)
BTW, What's the default I2C speed of BQ27Z746? 400Khz or 100Khz?
write to 0x56 nak
write to 0x55 ack data: 0x3E 0x02 0xEE 0x00 0x00
read to 0x55 ack data: 0x54 0x00 0x86 0x01 0x40 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
