Its noted that only one resistor available at the REF pin which is connected between GND and REF pin.
We planned to control the REF pin using DAC for adjusting the O/P voltage. Noted the it doesn't have have the R1 resistor which will be connected between Vout pin and ADJ.
Could you please confirm whether we can able to control the REF pin using External DAC?
