Hi Expert,
When high side switch drives capacitive load and turn off, the cap need to discharge. I suppose the cap cannot discharge through MOSFET body diode since the Vbb > Vout still. The cap will discharge via other path, right?
And I see in datasheet that the high side will not act to inverse current even when disabled. The inverse current will flow through body diode. Will this cause some damage to the MOSFET or chip? Thanks.
BR,
Elec Cheng
