Part Number: BQ75614EVM-021
Other Parts Discussed in Thread: BQ79616
Is it possible to stack 2 (or more) BQ75614EVM modules to get a higher voltage BMS? See below drawing. By stacking I mean tying the load lines in series. Will the below configuration work using 3 BQ75614EVM-021 boards?
If I was starting from scratch and wanted to use your EVAL boards for a proof of concept, whch EVAL board(s) would you recommend I use to build a >16 cell BMS?
