Problem Description: After loading several configurations from the online GUI to the TPS25750EVM, an error message will show up and prevent the user from loading in any new configurations even after power cycling and reconnecting the EVM.
Workaround: After unplugging all the cables remove jumper J4 as shown below:
While the jumper is disconnected, re-connect the EVM and load the configuration. If the error message shows up again, disconnect power and reconnect J4 jumper. After J4 is put back on, reconnect and load the configuration. This should resolve the error and user can now load the EVM with new configurations.
