Other Parts Discussed in Thread: AWR2243
HI IPM team
1. My customer Freetech used LP876242 to provide the power supply to AWR2243. In customer application, GPIO1 need to be re-configured to EN_DRV function. After the system is powered up, the EN_DRV pin(GPIO1 pin) output low level after set 0x31=0x20, 0x82=0x02, 0x80=0x01. And readback the INT registers(0x5a-0x6C0 but no any interrupt can be detected by PMIC . which mean EN_DRV should output high level. Would you help share your comments? how to correctly reconfigure GPIO1 as EN_DRV function after system is powered up?
2. Would you help share the demo code on SPI CRC calculation to customer for reference?
