UCD90124A: Power on/off sequence not work well
Part Number: UCD90124A
Hello team,
My customer have adjusted some settings of UCD90124A and now the power-on sequence seems working.
I would like to implement the power-off sequence and set the rails to operate based on the command to turn on/off which allows soft off feature.
By trying the SMBus/I2C debug tool in the Fushion, I got the below result:
1. Setting the rails to react to OPERATION command, and program the design to the PMIC device.
/resized-image/__size/1542x331/__key/communityserver-discussions-components-files/196/38562.jpg
2. Use the debug tool to send the I2C write to get the device turns on, write 01 80h based on the register bit.
/resized-image/__size/914x591/__key/communityserver-discussions-components-files/196/31460.jpg
3. The SMBus/I2C debug tool writes and reads the register 01h, showing ACK. However, the PMIC rails are not turned on. Could you advise what I might be missing?
/resized-image/__size/1006x900/__key/communityserver-discussions-components-files/196/47562.jpg
Your advice is appreciated.
Akihisa Tamazaki
