TPS61196: Tying the UVLO pin to VDD
Part Number: TPS61196
Hello
I am not using the UVLO function of the TPS61196, as per page 13 of the datasheet, I intend to pull the UVLO pin to VDD pin of the TPS61196.
Should this connection be direct, or through a pull-up resistor? If a resistor should be used, is there a limitation on the resistor value?
Many Thanks
