TPS7A94: RFB_PG(BOTTOM) Caculation
Part Number: TPS7A94
Hi team,
i just can't understand the caculation of RFB_PG(BOTTOM) as the picture shows. Could u kindly explain it?
  • Hi Zoey,
    The R_FB_PG(BOTTOM) is calculated in the second column and then plugged into the formula in the third (outlined in red) column. The choice of which R_FB_PG(BOTTOM) to use depends on the output voltage and the desired I_CL setting, as indicated in columns 1 and 4, respectively. Does that help?
    Nick
