Other Parts Discussed in Thread: TPS5430
Is it possible to use the automotive chip TPS5430-Q1 in the same way annotated in the application notes of TPS5430 describe to invert the voltage produced? I don’t see why this would be an issue unless there is a difference in silicon from the automotive to the consumer versions of the product but I would like to confirm this with the technical team behind them.
SLVA257A–January 2007–Revised August 2007
Using the TPS5430 as an Inverting Buck-Boost Converter
Using the TPS5430 As An Inverting Buck Boost Converter (Rev. A
Adam
