TPS55288-Q1: Vout tolerance
Part Number: TPS55288-Q1
Hi team,
Could you advise a tolerance of TPS55288-Q1 output voltage when it is set by internal register?
I would especially like to know the tolerance at VOUT=6.3V.
In the datasheet, there is a tolerance for 5V/10V/15V/20V, but each tolerance seems slightly difference,
so I would like to know the parameter which affect the tolerance.
regards,
