Hi Team
There is a good news that we DIN LP8866!
Could you please help confirm the design and Schematic is ok? THX
Hi Team
Hi, Kygo
I will give you a feedback by email for this case.
Hi Zhiqian
I have updated the design tool ,THX
LP8866-Q1_Design Tool_for Publish_Final_Protected(xg) Ver.01_TI_1027.xlsx
Hi Zhiqian
Thank you for checking the SCH!
For the Gain Margin result is OK? THX
Hi, Kygo
This is the Gain Margin gap, not the gain margin.
This value is fine for the calculation tool.
Hi Zhiqian
For LP8866 issue
FSW = 400KHz; the frequency multiplication after spreading is affected at 800KHz, 1200KHz, 1600KHz!
At present, it is confirmed that it is affected by LP8866. Customers have tried FSW = 200KHz, 303KHz, and 500KHz frequency multiplication, all of which affect this frequency band.
Test method CISPR 25 / Radiated emissions from components/modules - ALSE method
In addition, I would like to ask what is the upper limit of RG in Datasheet Table 8-3?
Hi, Kygo
I cannot understand your request clearly.
RG limit is related with FET, at least FET can work normally.
Hi Zhiqian
Thank you!
Currently I have the following approach:
HI, Kygo
RG will influence the rising time and falling time of GD.
You can check if the lower rising time can be accepted by FET and estimate the ripple influence of boost.
