TPS2041B: TPS2041B
Part Number: TPS2041B
We had received two different batches of TPS2041BDBV. We are using this IC from long time but unfortunately, it is been observed few of the ICs are giving pulses at output instead of constant voltage. We would like to understand more detail on batch code.
IC, Power Switch, High side MOSFET, 2.7-5.5V, 0.5A, SOT-23
Texas Instruments
TPS2041BDBV
Internally we were brainstorming on the physical appearance of ICs (batch code). There is difference on the marking of two ICs. Can you please explain us in detail(technical features) batch code/marking of the two ICs.
PFB: Images difference highlighted in yellow. Please consider this as high priority since production has been stopped.
                                      Bad IC        Good IC
Thanks & Regards
Vineet(9606571746)
