Part Number: TPS6594-Q1
We observed the IC will permantly shut off the output if under voltage happens for several times.
Even, we set enable = 0;
I don't need this function. Do we have any way to disable it by register or OTP?
This mechanism is not able to be shut off. When the recovery counter reaches 15 the pmic will stay in a safe mode and will not power up. However, a POR (<2.7V VCCA) resets the recovery counter. I would recommend increasing input capacitance to prevent under voltage on the pmic vcca.
Daniel W
After reaching 15 restarts, the pmic will be stuck in safe recovery until a POR (VCCA <2.7V)
Daniel W
