What is the resistance (nominal and across temp) across the WDO FET when WDO is pulled low for the following
TPS3431SDRBR
TPS3851G30EDRBT
TPS3851G33EDRBT
TPS3431SDRBR
TPS3851G30EDRBT
TPS3851G33EDRBT
Hello Adam,
We do not specify this parameter. Recommended pull up resistor values are in the datasheet.
Hope that helps.
