Battery Fuel Gauge Recommendation - 4/5 LED output
Other Parts Discussed in Thread: BQ24610, TPS61023, LMS33460, BQ40Z50
Hi all,
My current setup has a 2 x 18650 (Panasonic NCR 18650B) cells in parallel being charged by a BQ24610. Output from the 18650 runs through a LMS33460 3v under voltage protector and into a 5v 3.7a Boost converter (TPS61023).
I would appreciate some suggestions on what battery fuel IC should I choose, as the only function we would like it to perform is indicating battery % via 4 to 5 PCB mounted Led's. Is this possible and if so what would you recommend?
Thank you in advance
Chris
