Hi. I have a question about the value of resistor R1 at Figure. 31 in the datasheet.
- Can I omit this resistor?
- What is the maximum allowed value for R1?
Best regards.
Best regards.
Hi
I will check it and give you a feedback tomorrow.
Hi, R1 is recommended to be added and typically with 5.1 ohm, recommend not over 10 ohm
yuchang
PGND bouncing without R1 is much bigger than having R1, which may cause some damages to the part.
