Other Parts Discussed in Thread: TPS62091, TPS62093
Hello TI Team,
I am trying to get regulated output 1.05V @ 1.3A (Nominal current) from 5V Input Supply using the TI Component TPS62090RGTR.
Switching Freq.- 2.8MHz,
Start-up Time- 0.68ms
I tried to simulate the circuit on web-bench, TINA, and Pspice. But TPS62090 is not even able to generate a stable 1.05V @1.3A or higher current up to 3A. Please find attached waveform to see the simulated results.
All simulations like startup, Load Transient, Line(Input) Transient, and Steady State are completely failing.
You are requested to help me out with this. Shouldn't Use this component?
Thank You
Raj Kumar
