LM25149: Negative current limit
Part Number: LM25149
Hi team,
Is there a negative current limit threshold in LM25149? It seems like there isn't any negative current limit. Would it be a problem if I sink current at the output? Input voltage to buck converter can sink the current.
Shaury
  • Hi Shaury,
    There is no negative current limit. Note the negative current will sink to GND through the lowside FET if the VOUT is over-voltage.
    The input will only sink the current if the input voltage falls below the output voltage. This will be conducted through the highside FET.
    -Orlando
