Other Parts Discussed in Thread: TPS61094,
I looking for the solution about USB (5V) and AA battery ×2 (2~3V) with nearly Power path management.
(When system load higher than I_USB, I_BAT provide current fill in the gap)
I trying to make solution referenced by TPS61094 below, changed points are USB input and AA battery should not charge (it should reduce buck mode).
Example case of TPS61023, I imaging below solution.
Is there any problem or careful points, or required function?
Satoshi
