Hi Team,
As title, I used below website to get FIT.
It's different from functional safety document. May you let me know your idea?
Also, may you share when will we use MTBF information? Thank you.
Roy
Roy
Hi Team,
Roy
Roy
Hi Roy,
I just got further explanation of the difference in the MTBF/FIT estimator and the actual functional safety information document.
I quote , " The MTBF/FIT calculator open to the customers shows the typical “Bath Tub” device mortality which is based on reliability data and customer returns. For functional safety purposes the FIT rate that needs to be used has to come from standards such as IEC62380 and SN29500. These calculate FIT rates based on transistor count, package size, power dissipation."
Jimmy
Hi Jimmy,
Thank you for your information.
Can I say if we want to calculate the system total FIT to meet ASIL level, we may follow ISO26262 standard. So I need to use LM614xx-Q1 Functional Safety, FIT Rate, Failure Mode Distribution and Pin FMA (Rev. B)
May you share the scenario that we can use MTBF/FIT calculator?
Roy
Hi Roy,
I think the customer can use the MTFB results since it is based on reliability data and customer returns to get a understanding of the susceptibility of the device. However when talking about FIT rate values, it must follow the standards as previously mentioned so customer should simply reference the functional safety document for all questions related to that.
Jimmy
