Hi
I want to design a circuit in Tina TI as I designed using Proteus software. The Proteus software circuit with inputs and outputs are given in the pdf attached below.
I tried to design the circuit in Tina but this doesn't work for me and doesn't give me exact outputs as shown in the pdf.
As you can see in the pdf, when I apply input from 90 to 220V AC, it gives me 60 to 64V DC output.
Kindly help me figure out the problem in the circuit (attached below) as soon as possible.
Usman Haider
