Hi, TI
We met a problem when implement SM [CRC on Register Map].
We enable the SM by set GENERAL_REG_1.REG_CRC_EN = 0b1 to check the CRC. But the SW will get reset, the only info I can get from log is that "Reading on-board EEPROM at 0x51 failed 1"
So do you have any suggestion why the issue happen? Is there any essential steps I shall do before set the register?
Thank you!
Zhihua
