Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS54160: TPS54160DGQR
Part Number: TPS54160
I got this part with mismatch thermal pad dimension against the drawing. Is this OK?
It is even less than the thickest stencil recommended design. I wonder if this might cause solder overflow?
Ireen
