TPS92611-Q1: TPS92611-Q1
Part Number: TPS92611-Q1
Hi team,
Customer is using tps92611-q1 to generate constant current source for High voltage interlock system. As the external load increasing, the current will decrease to 4mA. Could you please help me understand how the device will behave with load increasing? Will the output current keep at 4mA minimum? Thanks
Scarlett
  • Hi Scarlett,
    1.What are output current/voltage and supply voltage in normal condition? and how does external load increases?
    for better analysis, hope you share the SUPPLY/IN/OUT voltage waveform and output current waveform in normal/4mA condition or schematic.
    2. About this application "Customer is using tps92611-q1 to generate constant current source for High voltage interlock system".
    Could you share more details?
    BR,
    Hailee.
