Our customer has evaluated bq25886 with their test board now, then they are facing the problem as below. Please let me know if you need more information.
[Problem]
- The charging is not started with 5.0V input for 8.0V battery
- The charging is started with 4.3V and 6.0V input for 8.0V battery
- At 5.0V input, the charging is started when the bq25886 and external components are heated by heat gun (Under high temperature environment)
[Request]
- Can you check following waveform and give any comments to correct this problem?
- I can share the shematic and PCB layout of their test board via private message or email, so can you contact me directly?
[Waveform]
Satoshi / Japan Disty
