Hi team,
Here
TPS25210ARPWR this eFuse part number is used in my design and same model i used for pspice simulation.
I have an issue by using this IC model while using for temperature sweep analysis. -10 TO 20 CELSIUS DEGREE i am able to run the simulation but if i increasing or decreasing temperature. I am getting error , PARTICULAR IC
TPS25210ARPWR DIVIDE BY ZERO in simulation.
Can you pls let me know the solution for this issue. or This IC has any limitation for temperature range.
Vinay Varikooti
