hello comunity,
is there any equation on how to define the exact value of the bias resistor.
The driver is supplied by a 12V voltage regulator 400mA max load current.
hello comunity,
Hello Akssas,
That resistor is there to act as an RC filter for the driver. It slows down the dv/dt. The datasheet recommends 10 ohms.
Ethan Galloway
Hello, thank you for the answer, I agree but it cuses a drop as well for the bootstrap during the low battery voltage.
How we can calculate the exact resistor value for a defined voltage?
Hello Akssas,
You need to make sure the VDD ramp up time is larger than 20 us. I think you can calculate the rise time by using the RC network equation and plugging in the VDD voltage.
I've got a few questions to ask about the circuit.
How is the circuit not working? How low of a battery voltage are you seeing? How large of a voltage drop are you seeing on RBias?
Ethan Galloway
