BQ24735: is there a way to turn the charger on and off
Part Number: BQ24735
Hi Team,
Do you know if it is possible to turn it off ie even though power is available you can turn off all switches ?
  • Hi, Ajayt,
    You may consider pulling down ILIM pin to disable the converter. "Once voltage on ILIM pin falls below 75 mV, charge (buck mode) or discharge (boost mode) is disabled. Charge and discharge is enabled when ILIM pin rises above 105 mV."
    Tiger
