TPS1H100-Q1: pulling up CS pin with 5V
Part Number: TPS1H100-Q1
Other Parts Discussed in Thread: TPS1H100B-Q1
Hi team,
My customer has one question about TPS1H100B-Q1
In the discription about CS pin, it says  The CS pin can also report a fault by pulling up the voltage of VCS,h”.
Does it means that by pulling up the CS pin by an external power supply, it will just work as a H/L fault reporting pin?
Also, in the datasheet, VCS,h is typ4.75V.
Is it OK to pull it up with 5V rail?
Ohashi
