BQ34Z100EVM: configure issue
Part Number: BQ34Z100EVM
Other Parts Discussed in Thread: BQ34Z100
Hi, team:
   I am testing BQ34Z100 use EVM, and wants to test >5V situation, When I configure VOLTSEL bit in GUI found it couldn't be changed. Could you help check it?
 I use 10V stabilized voltage source, and J5 has been moved to >5V, J2 set 16V liked user guide.
  • Hello Hailey,
    Write all Data memory when in single cell mode and then apply the voltage divider. Otherwise you may end up in a situation where the voltage reading of the gauge is below threshold to change data memory
