TPS2HB16-Q1: TPS2HB16AQPWPRQ1 TI Replacement to STMicroelectronics VND7020AJTR
Part Number: TPS2HB16-Q1
Good Day.
Is TPS2HB16AQPWPRQ1 a replacement for STMicroelectronics VND7020AJTR?
Please advise. Thank you very much.
Ray Vincent
  • Hi Ray,
    They are both dual channel high-side switch with similar Rds-on. They're not pin-to-pin compatible, and some spec such as current limit level and current sense accuracy are not the same. If customer is asking for a similar feature replacement, then it would be a good choice. Are there any specific feature requirements from the customer?
    Yichi
