Part Number: TPS92360
Other Parts Discussed in Thread: TPS61165, TPS61500
Datasheet mendtion TPS92360 only support PWM dimming signal frequency 5~100khz,
Does any other similar prodcut can support to 1~2khz?
Thanks!
Jeff
Hi Jeff,
TPS61165 can be an alternative. But why does your PWM can only be 1~2kHz?
BR
Patrick
Hi Patrick,
I found TPS61165 datasheet shows only support 5~100khz, or actually it can support to 1~2khz?
I think it old industrial panel design so only can support 1~2khz PWM output.
please see below spec.
Thanks!
Jeff
Hi Jeff,
It's recommended to use TPS61165 with PWM frequency= 5kHz ~ 100kHz.
But we used to test TPS61165 in a lower frequency about hundred Hz, it's also fine.
BR
Patrick
Hi Patrick,
Got it, I will apply sample or EVM for customer test. Thank you!
Jeff
Hi Jeff,
Sorry I made a mistake, I checked the bench test data and found that it's TPS61500 that can support 1kHz~2kHz PWM frequency.
BR
Patrick
