Other Parts Discussed in Thread: UCC28740, , TL431
Hi team,
I'm confuse about the function of COMP pin. I learned from the function of COMP is to compare it with CS signal to generate PWM signal. But I don't understand what the COMP signal is.
As datasheet desribing about COMP (green line part):
How does COMP pin work specifically? Could u please kindly clarify this simplified schematic about the opto part ? How does COMP voltage reduce with decreasing load?
Thanks & best regards
Victoria
