Hi, TI support team
Can the FLT pin and EN pin of the TPS2061CDBVR product be used together?
Internally, I think it will not be a problem if the FLT pin is connected to GND.
However, if there is an internal resistance, is it possible to calculate and apply the LOW LEVEL for the resistance value?
It is difficult to confirm because the details of the internal block are not described in the datasheet.
If you configure the circuit as above, please check if there is any problem.
Please, reply.
Thanks.
MJ
