UCD9248: Fusion Digital Power Designer Fatal Error during "Looking for USB Serial Adapter"
Part Number: UCD9248
Other Parts Discussed in Thread: USB-TO-GPIO2
I've been trying to launch the Fusion Digital Power Designer to access my device, however every time I launch the Fusion Designer GUI, it throws an error shown below:
I have tried running it administrator, same issue.
I have downloaded and installed the fusion software API (slvc459f) and TI Fusion API (slvc460) and it still doesn't work.
I am running Windows 10 and using the USB Interface Adapter EVM to connect to the device.
Is there anything else I can try?
  • Hi, Ky Ho,
    First, please uninstall Fusion software API and TI Fusion API since these 2 softwares have nothing to do with Fusion GUI.
    Second, is there any other software installed in the same folder as Fusion Digital Power Designer?
  • Hi Anne,
    Okay, I have removed the two softwares from my computer. In my x86>Texas Instruments> Fusion Digital Power Designer folder, I have these files:
    Ky
  • Hi, Ky,
    Can you show what are under x86\Texas Instruments folder?
    Also what happen if you launch GUI from x86\Texas Instruments\Fusion Digital Power Designer\Bin folder (click on Fusion Digital Power Designer.exe)?
    Anne Ngo
    Texas Instruments
  • Hi Anne,
    The only thing in the x86\Texas Instruments folder is the Fusion Digital Power Designer folder. I also tried launching the Fusion Digital Power Designer.exe from the bin folder but it amounts to the same issue.
    I did try running the software in offline mode and got this error with a log when I tried scanning for a device:
    Overview
    Application: Fusion Digital Power Designer 7.7.1.0
    Operating System: Microsoft Windows NT 6.2.9200.0
    .NET Runtime: 4.0.30319.42000
    Memory Used: 121.00 MB
    Exception
    System.DllNotFoundException: Unable to load DLL 'USB2GPIOv2.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
       at TIDP.SAA.USB2GPIODriver.Sys_FindUSB2GPIOControllers(Int32& USB2GPIOControllerNumber)
       at TIDP.SAA.USB2GPIODriver.Create(HidDevice device, Int32 device_number)
       at TIDP.SAA.USB2GPIODriver..ctor(HidDevice device, Int32 device_number)
       at TIDP.SAA.USB2GPIOFactory.Discover(HidDevice[] devices)
       at TIDP.SAA.SMBusAdapter.Discover_Only()
       at TIDP.PMBus.Controls.Internal.a.h()
       at TIDP.PMBus.Controls.Internal.a.f(Object A_0, EventArgs A_1)
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at DevExpress.XtraEditors.BaseButton.OnClick(EventArgs e)
       at DevExpress.XtraEditors.BaseButton.OnMouseUp(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at DevExpress.Utils.Controls.ControlBase.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Loaded Assemblies
    Com.Muegel.Misc
       Version: 2.0.88.18709
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Com.Muegel.Misc.DLL
       Public Key Token:
    DevExpress.Data.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.DLL
       Public Key Token: 79868B8147B5EAE4
    DevExpress.Utils.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Utils.v6.2.DLL
    DevExpress.XtraBars.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraBars.v6.2.DLL
    DevExpress.XtraEditors.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraEditors.v6.2.DLL
    DevExpress.XtraGrid.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraGrid.v6.2.DLL
    DevExpress.XtraPrinting.v6.2
       Version: 6.2.10.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.XtraPrinting.v6.2.DLL
    DundasWinChart
       Version: 7.1.0.1810
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DundasWinChart.DLL
       Public Key Token: A4C03DCE5DB22406
    Free.CommandLine
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.CommandLine.DLL
       Public Key Token:
    Free.Hid
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.Hid.DLL
       Public Key Token:
    Free.Misc
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.Misc.DLL
       Public Key Token:
    Free.WinForms.Misc
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Free.WinForms.Misc.DLL
       Public Key Token:
       Version: 7.7.1.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Fusion Digital Power Designer.exe
       Public Key Token:
    Microsoft.GeneratedCode
       Version: 1.0.0.0
       Info Version:
    <empty>
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
       Public Key Token:
    Microsoft.VisualBasic
       Version: 10.0.0.0
       Info Version:
    <empty>
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
       Public Key Token: B03F5F7F11D50A3A
    mscorlib
       Version: 4.0.0.0
       Info Version:
    4.8.4515.0
       Location: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
       Public Key Token: B77A5C561934E089
    System
       Version: 4.0.0.0
       Info Version:
    4.8.4536.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Configuration
       Version: 4.0.0.0
       Info Version:
    4.8.4190.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
       Version: 4.0.0.0
       Info Version:
    4.8.4590.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Data
       Version: 4.0.0.0
       Info Version:
    4.8.4584.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    System.Data.DataSetExtensions
       Version: 4.0.0.0
       Info Version:
    4.8.4084.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
    System.Drawing
       Version: 4.0.0.0
       Info Version:
    4.8.4390.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Numerics
       Version: 4.0.0.0
       Info Version:
    4.8.4084.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
    System.Web
       Version: 4.0.0.0
       Info Version:
    4.8.4494.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
       Version: 4.0.0.0
       Info Version:
    4.8.4550.0
       Location: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Xml
       Version: 4.0.0.0
       Info Version:
    4.8.4084.0
    TIDP.DevEx.Skin1
       Version: 1.0.0.0
       Info Version:
    <empty>
       Location: file:///C:/Windows/assembly/GAC_MSIL/TIDP.DevEx.Skin1/1.0.0.0__95fc6c5621878f0a/TIDP.DevEx.Skin1.dll
       Public Key Token: 95FC6C5621878F0A
    TIDP.I2C.DeviceGUI
       Version: 1.0.0.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.I2C.DeviceGUI.DLL
       Public Key Token:
    TIDP.Misc
       Version: 7.0.0.18429
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.Misc.DLL
       Public Key Token:
    TIDP.Net.ProxyPrefs
       Version: 1.4.0.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.Net.ProxyPrefs.DLL
       Public Key Token:
    TIDP.PMBus
       Version: 7.0.0.18441
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.DLL
       Public Key Token:
    TIDP.PMBus.Design.TimeModel
       Version: 2.0.88.18431
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.Design.TimeModel.DLL
       Public Key Token:
    TIDP.PMBus.DeviceGUI.UCD3000
       Version: 7.0.0.18455
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.DeviceGUI.UCD3000.DLL
       Public Key Token:
    TIDP.PMBus.ParameterControls
       Version: 7.0.0.18450
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.ParameterControls.DLL
       Public Key Token:
    TIDP.PMBus.WinForms
       Version: 7.0.0.18453
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.PMBus.WinForms.DLL
       Public Key Token:
    TIDP.SAA
       Version: 2.0.88.18432
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.SAA.DLL
       Public Key Token:
    TIDP.SAA.WinForms.Misc
       Version: 2.0.88.18434
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.SAA.WinForms.Misc.DLL
       Public Key Token:
    TIDP.WinForms.Apps.DPGUI
       Version: 7.0.0.18460
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DLL
       Public Key Token:
    TIDP.WinForms.Apps.DPGUI.DPGUI1
       Version: 7.0.0.18465
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.DPGUI1.DLL
       Public Key Token:
    TIDP.WinForms.Apps.DPGUI.HelpCenter
       Version: 7.0.0.18434
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Apps.DPGUI.HelpCenter.DLL
       Public Key Token:
    TIDP.WinForms.Dundas
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Dundas.DLL
       Public Key Token:
    TIDP.WinForms.Misc
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Misc.DLL
       Public Key Token:
    TIDP.WinForms.Util
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/TIDP.WinForms.Util.DLL
       Public Key Token:
    XtraDataTempAssembly
       Version: 0.0.0.0
       Info Version:
    <empty>
       Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.dll
       Public Key Token:
    Maybe this log will help.
    Ky
  • Hi, Ky,
    It looks like you are using USB-to-GPIO2 adapter (2022) instead of USB-to-GPIO 2006. GUI 7.7.1 does not support USB-to-GPIO 2022, and I am not sure why GUI 7.7.1 looking for USB2GPIOv2.dll.
    Please uninstall all Fusion Digital Power Designer software on your computer; and then reinstall the correct GUI version.
    If you are using USB-to-GPIO 2006, you can reinstall v7.7.1. If you are using USB-to-GPIO 2022, you will need to install the later beta GUI version.
    Anne Ngo
    Texas Instruments
  • Hi Anne,
    Yes, I am using USB-to-GPIO2 2022. Could you please point me to the correct GUI version that supports this model?
    Thank you,
    Ky
  • Hi, Ky,
    Here is the link to beta GUI that supports USB-to-GPIOv2: TI-Fusion-Digital-Power-Designer-7.8.3.zip
    Anne Ngo
    Texas Instruments
