BQ40Z50-R1: BQ40Z50-r1 change the Term V from 3000mV to 3450mV, Qmax update fail
Part Number: BQ40Z50-R1
Hi
It is normal to use BQ40Z50-R1 with 1S1P/4040mAh according to the normal learning procedure
(CHEM ID: 2052, application range voltage: 4.2V~3.0V) update=  06
Later, due to the customer's system design adjustment, Term V change from 3000mV to 3450mV, QMax can not be updated, and it is found that RSOC will not be calculated when charging below 3.7V
How to regenerate the golden file.
Waiting for your reply.
Star
