LMR36520: Thermal shutdown and OC
Part Number: LMR36520
One question about application.
if Thermal shutdown and short current are happened at the same time, how is the device behavior? Does IC go to retry mode? if yes, it should have safety concern, right?
  • Hello
    When the TSD engages, the device will shut off until the temperature falls below the threshold stated in the data sheet.
    If the device is in short circuit mode, it will continue in that mode until the TSD shuts off the device.
