LP5907: Questions of LP5907
Part Number: LP5907
Dear Team,
Please refer this post as below,
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1177730/lp5907-questions-of-lp5907/4437442#4437442
There is no abnormality in the temperature measurement of the board with waveform problems. What is the reason for the abnormal output voltage waveform?
Many Thanks,
Jimmy
  • Hi Jimmy,
    Can you please provide the measurement method? I.e. the kind of probes and where the connections were made on the board.
    Can you also provide an AC-coupled waveform of the output so that I can see more details of its behavior? Please include a zoomed in waveform to show the small-signal ripple if there is any. If the device is unstable it should be apparent in this zoomed-in waveform.
    Nick
