HI Sir
We try to initial the TPS65086100 , but we fail, could you help to provide the source code let me to check it?
below is our register & schematic,did they correct?
thanks
HI Sir
thanks
Hi Alex,
Thank you for reaching out via E2E. So I can best assist you can you help to further clarify what specifically is not working with the TPS65086100?
We provide a Linux driver for the device, which can be found under software development on the product page on TI.com linked here: TPS650861 data sheet, product information and support | TI.com. Other than the Linux driver and a GUI tool we do not have any other source code. For programming the device and using the OTP generator tool I recommend referencing our programming guide linked here: TPS65086100 Non-Volatile Memory Programming Guide.
I will work to review the schematic you provided and you can expect feedback by the middle of next week.
Garrett
Hi Alex,
Please see my comments below for feedback on your schematic provided.
All other connections look good. I await your reply in regards to the details of the issue you are seeing.
Garrett
