Other Parts Discussed in Thread: CSD87381P, TPS3808
I plan to use TPS65086470 with Artix-7 but I am quite confused about how to use it,especially its CTL pins. As I understand from its datasheet, thanks to its OTP property, we dont need to do anything about its integration with Artix-7 and about the power sequence. Is this right?
Below shows my configuration and I believe that this configuration is already embedded in the TPS65086470.
Input=LDO5 /// BUCK_1 + CSD87381P => 1V0 for VCCINT
Input=LDO5 /// BUCK_2 + CSD87381P => 1V8
Input=External 5V0 /// BUCK_3 => MGT1V2
Input=External 5V0 /// BUCK_4 => VCC_2V5
Input=External 5V0 /// BUCK_5 => VCC_3V3
Input=LDO5 /// BUCK_6 + CSD87381P => VCC_1V35
Input=BUCK_6 /// VTT_LDO => VTT_0V675
LDOA_1, LDOA_2, LDOA_3, SWA_1, SWB_1, SWB_2 => NOT USED //// I believe PVINLDOA2_A3, PVINSWA1, PVINSWB1_B2 should be connected to GND??
For the above configuration, what should I connect the CTL pins? In the evaluation board, all CTL pins have pull-ups and also connection to GND through a switch.
Ulas.
