Webench is not calculating an output tolerance for this design https://webench.ti.com/appinfo/webench/scripts/SDP.cgi?ID=E5C2527BDB81BD95
Is there a setting that needs to be changed.
Hello
Probably because you are looking at an IBB.
However, the tolerance you get with an IBB will be the same as for a positive buck.
If you design a +15Vout buck with Webench Designer, the tolerance it predicts should be applicable to your -15Vout.
