For this thread, https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1188239/ucc24624-application, I need some help for finding Flyback controller for the auxiliary power supply in Boost PFC + LLC.
Previously I was used Power Integration IC TNY288KG. Can you please suggest.
Requirement-
1. compatible to TNY288KG like inbuilt internal switch, VDS rating and maximum power rating etc.
2. But I do not need isolation between primary & secondary. (Remove Opto-coupler)
3. Two output voltages (12V, 600mA & 18V, 500mA) in the output side. I have use stacked winding in the secondary side for 12V & 18V.
4. I want to sense 12V output in FB pin for better regulation.
Please provide your suggestion.
I will share the schematic on mail.
Thanks & Regards,
Raj Kumar Chaurasiya
