TPS62870-Q1: Land pattern size
Part Number: TPS62870-Q1
Hi, Team:
Can you help to check and update Land pattern size?
The size in datasheet seems not enough to build PCB library.  I add the items customer need in red.
  • Hi Alpha,
    Package follow the similar on all corner. Corner dimension would be similar as suggested in bottom left and distance  between pin are always same.
    Let me know if any information is missing.
    Tanvee
