TPSM82816: IR3475 and IR3473 replacement inquiry
Guru 10920 points
Part Number: TPSM82816
Other Parts Discussed in Thread: TPS56C231, , TPSM8A28, TPS54824, TPS543820, TPS543620, TPS56637, TPSM82866A
My customer is looking for a TI power solution to replace the IR3475 and IR3473 respectively.
They are looking at the TPS56C231 or TPSM8A28 as a replacement for the IR3475. And considering the TPSM82816 as a replacement for the IR3473.
 - https://www.infineon.com/dgdl/ir3473m.pdf?fileId=5546d462533600a4015355cca86d1727
 - https://www.infineon.com/dgdl/ir3475m.pdf?fileId=5546d462533600a4015355ccb1401729
Can you recommend suitable alternatives for each product?
Additionally, the customer wants to privately share their existing schematics to review the suitability of replacing them with TI products. Is it possible?
Thank you.
JH
