TPS54J061: TPS54J061 design calculator
Part Number: TPS54J061
Hello, Team
our customer sees the difference on the formula of Rtip between design calculator and datasheet,
they want to know which formula could they use.
may i have your help to ranswer this question?
datasheet:
design calculator:
  • Hi King,
    The formula that you are showing in the calculator is not the entire/whole calculation for current limit.
    The formula in the calculator is for Irriple_min which is the inductor ripple current at vin_min and includes the tolerances of the inductor. This is only the part of the formula circled in red below.
    You still need to divide the ripple by 2 and add it to Ilim_valley in order to get the Iout_Lim(min).
    Therefore, there is no conflict between what the calculator shows and what the datasheet suggests.
    Hope this makes sense.
    Yitzhak Bolurian
  • Hello, Yitzhak
    understand, thanks.
