TPS4811-Q1: Disable Curren Sense Function
Part Number: TPS4811-Q1
Dear Team,
My customer is considering to use the TPS4811-Q1 to turn on/off an external Nch-MOSFET to switch DC42V power line now. Their application already has the current sense and current limit features. Since shunt resistor supply is still not good, and the price of shunt resistor is high, they want to use the TPS4811-Q1 as just high-side driver without the current sense funciton.
Q1:  Can they use the TPS4811-Q1 by shorting the CS+ pin and the CS- pin and disabling the current sense function?
Q2: Are there any side effects to the TPS4811-Q1 of this?
        *Their application already has the current sense and current limit features.
I look forward to your reply.
Thank you.
Koshi Ninomiya
