The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
BQ24105-Q1: Charge and termination loop
Part Number: BQ24105-Q1
Hello Experts,
Please let me know if the BQ25105 will be in charge and termination loop what is the impact on IC health , there any chance where i will loose this IC
As per my vehicle arch. this may be in the same loop time for 5-6 hour.
Page Number 24 of datasheet
Other Issue:
If the system load current is large (≥ 1 A), the IR drop across the battery impedance causes the battery voltage to drop below the refresh threshold and start a new charge. The charger would then terminate due to low charge current. Therefore, the charger would cycle between charging and termination. If the load is smaller, the battery would have to discharge down to the refresh threshold resulting in a much slower cycling. Note that grounding the TTC pin keeps the converter on continuously.
  • HI Dinesh,
    There is no impact on IC health.  The charger was designed to charge to termination, then stop charging and then recharge only after the battery has discharged below a certain threshold.  The datasheet statement is only to explain what happens if a load, attached to the battery, causes the charger to either not terminate or rapidly enter/exit termination.
    Jeff
